Bayou Bert's RV9A Web Site
Date:  4-25-2014
Number of Hours:  4.50
Brief Description:  MAP Sensors
I had to mount two MAP sensors. The MAP sensor tells the electronics
what the manifold pressure of the engine is at any given time.
One sensor, the black one on the engine side talks to the Electronic Ignition
for the bottom spark plugs. The one mounded inside the plane talks to
the GRT onboard computer.
EI sensor and bulkhead fitting
Inside sensor and plumbing
Sensor feed from engine
